Dc train motor
tapan6415
Joined Mar 11, 2011
9
hello,
i made electric model train of 5kg
i used 12 v dc motor 60 rpm
train also include internal led lighting
but it can not able to take load of train
can u tell me plz how much rpm or how much voltage motor required to take load of my train
tapan6415
Joined Mar 11, 2011
9
so, u mean to say 180 rpm motor will be able to carry this 5kg load..?
also tell me i have to seperate power supply from led and motor or single is working.?
debjit625
Joined Apr 17, 2010
790
What does that means?
Do you want to know that if you need two power supply or a single one....if yes ,then it depends on your circuit ,both will work
Bernard
Joined Aug 7, 2008
5,784
12 V X 2 A = 24 W; motor turns at about 3000 RPM ; gear reduction around 17:1 to give 180 RPM of drive wheels, or about 3 miles per hour. A single 12 V 4 A power supply should do.
Bernard
Joined Aug 7, 2008
5,784
My guess was 12 V @ 2 A for motor. RPM and gear train will depend on motor. Motor will be about 1.5 in dia. X 2 in long, [ that is a big about].
Power supply 12 @ about 4 A. Do you have more information on train?
tapan6415
Joined Mar 11, 2011
9
no i have not more information but i want more about motor, as well as my train lighting circuit , if u help me then its good for me.
