I'm creating a dc to dc booster circuit and I am wondering if it keeps the same frequency going out as coming in to the MOSFET? Even when stepping up the voltage.
Very dangerous to remove all capacitors because the output voltage will go to hundreds of volts. You will be doing a balancing act with the frequency, capacitance, and the load resistance to get a stable wave shape.is there. Safe way to take out the capacitors and not have a overload.
Yes I want it to amplify.Sounds like you wanna make some sort of voltage amplifier.
Superman185.:
What voltage, waveform, frequency and current is your input signal?
What voltage, waveform, frequency and current do you want at the output?
That is enough to KILL you !!600v, square, 2-4MHz, no more than .2amps coming out.
Ok it's enough to kill someone.That is enough to KILL you !!
As you clearly lack experience in converter circuits, don't even think about building one with this output.
by Aaron Carman
by Robert Keim
by Jake Hertz
by Jake Hertz
