DC to Ac inverter
Discussion in 'The Projects Forum' started by athulascc, May 17, 2015.
  1. athulascc
    Aug 15, 2014
    88
    [​IMG] [​IMG] i am wondering about this design.
    How it works?
    Can you give a hint
  2. djsfantasi
    Apr 11, 2010
    2,914
    881
    Unfortunately, one of your pictures cannot be seen? I guess - it was the schematic.
  3. crutschow
    Mar 14, 2008
    13,521
    3,388
    A hardware picture tells very little about how a circuit operates.
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Should be very simple to reverse engineer a circuit such as that with so few components.
    Max.
  5. athulascc
    Aug 15, 2014
    88
    yes. but I have not it really have. it is only image.
    I want to know the similar circuit or topology
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    No schematic, no idea.
    ak
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Judging by the apparent symmetry I'd guess the two tabbed transistors provide a push-pull oscillator drive arrangement for the primary of the bigger transformer. The smaller 'transformer' may be a just a choke.
    mattbullet likes this.
  8. Dodgydave
    Jun 22, 2012
    5,167
    777
    got any more pictures of different angles ,and the track side view.....
  9. DickCappels
    Aug 21, 2008
    2,782
    675
    It probably uses this topology (below) but without the snubbers (.01 uf capacitors and 22 ohm resistors) and probably without the output rectifiers and filter.
    One transistor will be on until the base drive transformer saturates then it will turn off, which in turn turns on the other transistor until the base drive transformer saturates in the opposite direction.
