dc to ac converter ( help )
Discussion in 'The Projects Forum' started by ht systems, Mar 16, 2012.
  1. ht systems
    Aug 2, 2011
    71
    Hello
    I want to build an ( DC to AC converter ) 12v , I draw a circuit but the output gives an AC forklift wave , not a sine wave .
    Is there any change i can do to make the output gives a sinewave or my design is right ?
    I uploaded the circuit as a pdf file .
    Thank you very much .
    • 1.PDF
      File size:
      19.8 KB
      27
  2. RFactor
    May 1, 2009
    33
    What is a "forklift wave?"
  3. ht systems
    Aug 2, 2011
    71
    sawtooth wave
  4. praondevou
    Jul 9, 2011
    2,936
    489
    Applying a squarewave to a transformer will not give you a sinewave at the output. Depending on frequency you will see a distorted squarewave or a sawtooth.
    You can transform this into a series resonant converter or drive your transformer with a sinewave modulated PWM...
  5. ht systems
    Aug 2, 2011
    71
    I want the output to be a sine wave not a sawtooth wave , this is my problem , is there anysite that i could have help with ?
