Furniture2all
- Joined Apr 17, 2010
- 4
Thank you for this circuit i do it and it workOK, threw together a 3-phase generator using an LM324. See the attached.
It's output frequency is about 19.2kHz, which is way too fast for your motors. But I did it that way so that it would be easier for you to see the pseudo-sine wave output.
If R5 through R7 are removed, the outputs become square waves and the frequency drops to around 250Hz, which should work fine with your motors. However, the opamp alone won't likely have enough current to drive the motors.
Note that R4 sets the voltage level for the + inputs of all three opamps. This is to allow adjustment for the duty cycle of the outputs; I wanted 50%. In this simulation, I wasn't worried about getting it exact; ballpark was enough. It really needs a 0.1uF cap to ground to eliminate noise.
Note that there should be a 0.1uF (100nF) bypass cap across the supply pins. This goes for just about any IC.
Please advice me how to operate with this circuit motor in with delta connection
and can i work the motor in star connection all the time
this is my email <snip>
i hope to here from as soon as u can
