DC source, Capacitor and LED
Discussion in 'General Electronics Chat' started by dipto, Dec 11, 2015.
  1. dipto
    Jun 11, 2015
    I have connected a variable capacitor and a LED in series with a DC 9V source. When I vary the capacitor , the brightness of the LED changes. But how it happens?
    RRITESH KAKKAR likes this.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    The capacitor will conduct until it's charged. Post a schematic for a better answer.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Means that the variable capacitor is shorted. Test it with an Ohmmeter.
  4. wayneh
    Sep 9, 2010
    12,396
    3,246
    Your 9V source may be pulsing, and the capacitor can pass current will charging. But you'd need a large capacitor for this. Mike's answer seems more likely.
  5. dipto
    Jun 11, 2015
    no, its just a 9V battery
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Which capacitor was that GANG?
  7. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    I think there is 9-volt battery and connect to a 470Ω resistor which is in series with a 100K potentiometer connected to an LED. We use a protection diode in this circuit so that if the 9-volt battery is inserted the wrong way, the LED can be protected from reverse current.
  8. wayneh
    Sep 9, 2010
    12,396
    3,246
    So it's really a variable resistor, not a capacitor?
  9. dl324
    Mar 30, 2015
    3,384
    653
    Make it easier for us to help you. Post a schematic of your circuit and a picture of your variable capacitor. How do you expect to limit LED current?
