dc socket earth pins
Discussion in 'General Electronics Chat' started by radetonator, Dec 5, 2011.
  1. radetonator
    Aug 1, 2011
    50
    normally DC socket has two earth pins, should both the earth pins be connected to the earth of the PCB?
  2. mcgyvr
    Oct 15, 2009
    4,783
    973
    Many times those pins also serve a mechanical purpose too. So yes I would attach them both
  3. radetonator
    Aug 1, 2011
    50
    what if only pin 3 is connected to the earth of the PCB? could this connection cause trouble?
  4. mcgyvr
    Oct 15, 2009
    4,783
    973
    Can you give the part number of the specific connector you are using?
    If it has 2 earth pins..connect them both. Companies/people are cheap now.. We don't just put pins there for decoration now.
