DC Series-Parallel Circuit combination
Discussion in 'The Projects Forum' started by walley, Feb 19, 2008.
  1. walley
    Feb 19, 2008
    Hi Friends,
    I have a power wheelchair run by two 12v batteries wired in parallel fashion until wires meet up at a power module. A lead wire comes off the module to each of the two 24v motor wheels.
    I recently bought a 24v urine bag drainer.
    My problem is the two batteries as said are wired in parallel.
    Can I also wire the same batteries in series to get 24v needed by drainer?
    Thanks, Leo
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    How does the power module get the 24 volts for the motors? Are the batteries wired so both positive terminals are physically connected and the same for the negative terminals, so only two wires run to the motor controller?
    This could be a problem, as they can be in series or in parallel, but never in both states.
  3. walley
    Feb 19, 2008
  4. walley
    Feb 19, 2008
    thanks beenthere,
    problem solved.
    it turned out to be a problem in my new device, a connection not crimped right.
    thanks for trying.
    Leo
