DC removable subtractor insted of filter
Discussion in 'General Electronics Chat' started by Goverdhan R, Mar 10, 2016.
  1. Goverdhan R
    Mar 10, 2016
    5
    i want know why this circuit is not working at all. i am trying to remove dc from signal( which has dc in terms of volts and ac in terms of mill volts) and i need to amplify ac signal. my assumption is that only dc is available for certain interval of time, so i will charge capacitor. After changing input some ac will be added to dc . so i tried to subtract with opamp and amplify ac as my interest is on ac.
    Suggest me what to do?
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Why can't you pick the AC signal off the DC with a capacitor?
  3. Goverdhan R
    Mar 10, 2016
    5
    ac signal i am interested is in frequency range of 1-2Hz and capacitor will offer high impedence for this frequency range and ac is of very low magnitude, so i was doubtful about using capacitor and made use of this circuit but not getting output. Any alternatives so i can remove dc and amplify ac signal of frequency 1- 2hz as i am using this for biomedical application.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    You are essentially feeding the same signals to a difference amplifier and you expect to get an output?
    What is the amplitude of the AC and the magnitude of the DC offset? Is the DC offset fixed?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    why the 1000 mfd cap to ground in the input? kind of defeats the ac dosnt it?
  6. Goverdhan R
    Mar 10, 2016
    5
    @dl324 this is for biomedical project. so dc offset varies for each patient( so not fixed) but remain same as long as it is connected to one patient.
    Dc offset is available while connecting to each patient.after some time signal will be mixture of ac and dc. Magnitude of dc in 3-4 volts and ac in millvolts
    @alfacliff So i can get dc which i want to subtract with ac+dc signal. But it is not happening
    shortly
    at t=0 input available is dc
    at t=to input available is dc+ac
    so i want to remove dc. AC is in terms of millvots and low frequency(1-2 HZ)
  7. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Try something like this:
  8. crutschow
    Mar 14, 2008
    13,505
    3,376
    You just make the capacitor large enough so that RC time-constant is long enough to pass the low frequency AC.
    For example with a 100kΩ input resistance, a 10μF capacitor in series will give a low frequency corner of 0.16Hz.
    That will readily pass your low level 1-2Hz signal but block the DC.
    Edit:
    Here's a simulation of the circuit.
    As you can see, the -3dB point is .16Hz and the rolloff at 1Hz is only -109mdB (-0.109dB) or an attenuation of 0.988.
  9. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Yup, that's much simpler ;).
