DC/RC problem
Discussion in 'Homework Help' started by Hazard111, Jan 2, 2015.
  1. Hazard111
    Jan 1, 2015
    13
    How to see if 5 bit number which can be in DC or RC format is greater than 9
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    What is DC or RC format?
    Hazard111 likes this.
  3. Hazard111
    Jan 1, 2015
    13
    Radix Complement (Two’s complement)/RC
    Digit Complement (Ones' complement)/DC
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    Write out a truth table of the five bits for all positive numeric values > zero. Use Combinatorial logic (sum-of-products) to create a single output which is true for 9<=value<=15.
  5. WBahn
    Mar 31, 2012
    18,065
    4,905
    I think you probably mean (or the author probably meant) "diminished radix complement" for DC.
    Break it down into pieces.
    What does the msb tell you in either case?
    Assuming that the number in question is positive, how can you use just the lower four bits to determine if the value is greater than 9?
    What would be the result if you subtract 9 from the number?
