ok now i know that a alternating magnetic field is used in a transformer but can you use like a transformer that is pulsed in say only one direction so like only positive on one side and only negative on the other. if you could then would you have a dc secondary only and no ac transformer. the reason i thought you might be able to is because when it is pulsed the voltage would rise and then fall and then the voltage would rise and so on and on the secondary the same thing would happen.
