DC Power Supply
Discussion in 'Homework Help' started by Ahmed Zafar Khan, Feb 18, 2016.
  1. Ahmed Zafar Khan
    Feb 18, 2016
    6
    I have designed a 5V ,350mA fixed power supply with a 12 Vrms step down transformer. the voltage across filtering capicitor should be almost peak value i.e 15V or 16V . but I am getting 12 volts acrossthe capacitor why is it so.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Schematic.
    Is the supply loaded at 350 mA when you are measuring the voltage?
    Schematic.
    What is the size of the filter capacitor?
    Schematic.
    ak
  3. Ahmed Zafar Khan
    Feb 18, 2016
    6
    YES IT IS WHEN THE CIRCUIT IS LOADED .
    5500MICRO FARAD 25VOLTS
    Please answer it
  4. Dodgydave
    Jun 22, 2012
    5,159
    772
    POST YOUR CIRCUIT PLEASE.
  5. Ahmed Zafar Khan
    Feb 18, 2016
    6
  6. crutschow
    Mar 14, 2008
    13,508
    3,385
    We mean the schematic.
  7. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Your question has been answered in the other forums.
  8. Ahmed Zafar Khan
    Feb 18, 2016
    6
    MAY IT WORK
  9. Dodgydave
    Jun 22, 2012
    5,159
    772
    NO, you have resistors in series with the output supply, and the zener is pulling too much current through the resistors, i would use a lm7805 regulator instead of the resistors and zener.
  10. Ahmed Zafar Khan
    Feb 18, 2016
    6
    SIR THIS IS OUR LAB PROJECT USING ZENER MY QUESTION IS WHY VOLTAGE DROPS ACROSS CAPACITOR THEORY BASED ANSWER NEEDED
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  12. ronv
    Nov 12, 2008
    3,404
    1,478
    The capacitor gets charged by the peaks only so the charge current is quite high. This makes the drop across the 1 ohm and the diodes higher than you think.
  13. WBahn
    Mar 31, 2012
    18,089
    4,917
    What is the average current through the 15 Ω resistor between the cap and the zener?
    What fraction of the time do the diodes spend conducting?
    What is the average current through the 1 Ω resistor between the bridge and the cap?
    What is the average voltage drop across that 1 Ω resistor?
  14. WBahn
    Mar 31, 2012
    18,089
    4,917
    Typing in all caps on a forum (or e-mail) is considered the equivalent of shouting and it is also considered quite rude. Please refrain from the practice (except, of course, when your intent is to shout and be rude).
