If I rememeber right, that is much more complicated. I'm only an amateurLearn enough to design a switched mode power supply. Then you can get the efficiency up and the heat out of the IC's.
You could also use relays and switch the primary and secondary windings to lower the DC input voltage to the adjustable regulator.
by Jake Hertz
by Jake Hertz
by Jake Hertz
