DC power supply module For HP 1610
Discussion in 'General Electronics Chat' started by Gompers, Mar 8, 2008.
  1. Gompers
    Feb 21, 2007
    18
    Can anyone tell me if I can build a power supply for the PSC All in one H P 1610
    The module was missing from the unit a friend bought for cheap. It needs a dual dc supply 16 VDC +32VDC
    I was thinking of combining two separate D C 'Wall rats',but,I suspect the original 's step down winding has a center tap to provide the two voltages.
    The female port for the module has three openings to accept a three pronged male plug (Which I'll have to fabricate) How would I pair two units and wind up with the correct application? The port is clearly marked with plus and minus and ground designations. Thanx Gompers
  2. S_lannan
    Jun 20, 2007
    247
    just a thought, see if the manufacturer has spares, a fabricated supply might be more expensive than the genuine spare.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wall warts are notoriously for poor regulation and nonsense specs. I would want to have a pretty good idea of the two levels of current involved. Considering that you have a few bucks sunk in the device, a couple of regulated supplies could be in order.
  4. Gompers
    Feb 21, 2007
    18
    Gompers;59181]Can anyone tell me if I can build a power supply for the PSC All in one H P 1610
    The female port for the module has three openings to accept a three pronged male plug (Which I'll have to fabricate) How would I pair two units and wind up with the correct application? The port is clearly marked with plus and minus and ground designations. Thanx Gompers.
  5. Gompers
    Feb 21, 2007
    18
    I googled up the unit. It goes for about 60 Bux
    Thanx for reply Guys
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hmmm - a quick check of Marlin P. Jones & Associates catalog shows they have 18V 4.2A supplies for $9.95/each as stock# 16684-PS
    http://www.mpja.com (home page)
    http://www.mpja.com/prodinfo.asp?number=16684+PS (direct link to supply)
    You may be able to connect a couple of them in series, and use three power rectifier diodes on each end to get +/-16v (assuming the rectifiers will drop about 0.7v across themselves.) That'll save you about $30. You will still need to build an enclosure, make an interface cable, etc. However, the supply you found will most likely need to have all of it's electrolytic capacitors replaced right away.
  7. JoeJester
    Apr 26, 2005
    3,390
    1,211
  8. Gompers
    Feb 21, 2007
    18
    JOE JESTER,thanx much.I ordered it . You saved me 40 bux
