DC Power Supply: A-D-A
Discussion in 'General Electronics Chat' started by RFingThePulser, May 7, 2007.
  1. RFingThePulser
    May 7, 2007
    Greetings everyone:
    I am a new member, and currently a college student about to graduate in less than two weeks. Although my degree is in chemistry, I recently decided that I really didn't want to do organic chemistry research for the rest of my life, so I decided to try out some new fields. I am taking my first real course in electronics this semester, in which I have a final exam tomorrow (don't worry, I'm not asking for exam help).
    Anyway, frequently throughout class, my professor made the remark that in his experience with electronics, a good portion of the problems and failures occur in the DC power supply. He also said that there have been very few technological advances with regard to power supplies in the last 30 years, such as that used by a laptop computer. Also, in that lecture, he pointed out how there is significant energy loss in the transformer coils, rectifiers, and filters, much of which causes heating.
    This got me thinking about an alternate method of producing DC voltage from AC mains. Basically, I was thinking of a method that would
    1. Digitize the incoming mains AC signal using an ADC.
    2. Convert the sinusoidal digitalsignal into a flat digital signal through some sort of logic circuit.
    3. Convert the flat digital signal into DC using a DAC.
    At this point in my education, I would not know how to accomplish step 2, but I'd be surprised if it couldn't be done, given what humanity has accomplished with digital logic circuits.
    Anyway, I am curious to know what research has been done in this area (I'm sure someone came up with this idea before me), and how the energy efficiencies of this method compare to energy efficiencies of existing power supplies.
  2. recca02
    Apr 2, 2007
    1,211
    are u talking about transmission of power using dc
    form what i know,
    the steps described by u are some what similar to conversion of analog signal
    to digital, but when you talk of power supplies a lot more practical complications
    are involved.
    first, there is no need for exact d/a conversion according to signal as no data is being transferred we only want to transfer power there is a great deal of difference between the two.
    also d/a conversion is different in the sense that data transmission is
    of importance here and power supply is used to amplify or even encode or decode the signal like in opamp .
    in general the power associated with supplies is so high that digital ckts wont
    even last against it. the heat dissipation wud easily burn away the whole ckt.
    i believe the voltage drops across these circuit wud be much more than
    what we have with conventional methods.
    try reading abt smps for some development in this field.
    btw ac transmission and distribution is far more advantageous than dc.
    btw organic chemistry is one of the most conceptual and beatiful subjects i have ever learned,
    reaction mechanism is the best (isnt it interesting to be able to predict product of any 'never seen before reactants")
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Most variable speed drives do this.
    They convert AC to DC, then recreate an AC sinewave of variable frequency using PWM and filters.
  4. recca02
    Apr 2, 2007
    1,211
    my knowledge is limited in this case,
    wud u plz care to elaborate a little as to why and how,
    is it conversion of ac to dc power, if so why is it required?
  5. John Luciani
    Apr 3, 2007
    477
    Your professor is correct about the unreliability of the power
    supply. Next on the list is the fan.
    He is not correct about the advances in power supply technology.
    Power supplies have evolved quite a bit in the last 30 years. Check
    out the DC-DC converters at www.vicr.com. Check out the various power
    supply controllers at Linear Technology, TI and OnSemi. I have a small
    switching power PCB layout with three converters at
    http://www.luciani.org/works-in-progress/works-in-progress-index.html
    My designs use the LTC and OnSemi controllers.
    The power supply in your PC is not advanced since one of the
    main design goals is price. The laptop is more advanced since
    two of the main design goals are efficiency and size. The laptop
    supply will trade-off price since laptop users are willing
    to pay for a smaller machine with longer battery life.
    The problem with using ADCs and DACs and logic is that all of those
    devices were not designed to process power efficiently. One of the
    most efficient ways to get to DC from AC is a bridge rectifier and a
    capacitor. To get an isolated low voltage DC you would convert your
    rectified AC input to high frequency AC signal. The AC signal would be
    connected to a step-down transformer and rectified to a low voltage
    DC.
    (* jcl *)
