Dc power line communication
Discussion in 'General Electronics Chat' started by bug13, May 10, 2014.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I have this problem, the following circuit work great until the power line was replaced with a longer cable, my first thought was the source and load impedance is mismatched, and some kind of signal reflection is happening. But I have no idea what is happening as I have no/little knowledge of this area.
    So my question are:
    - what cause it?
    - how do I fix it?
    When is working:
    local send a signal to remote unit, remote unit flash a led at ~1Hz
    When is not working: (after a new cable is installed)
    local send a signal to remote unit, remote unit flash a led at odd rate, it's more like a normal 1Hz + a short pulse between two or three normal 1Hz
    circuit: (updated, error on the original one)
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Are you sure the 11 ohm resistor is connected properly?
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Why is the lower comparator +input connected to the other signal, not the fixed Vreference? Is that just a schematic error?
  4. bug13
    Feb 13, 2012
    1,213
    38
    I have check the circuit again, The original circuit is two 22R in parallel, I just replaced them with one 11 R.
  5. bug13
    Feb 13, 2012
    1,213
    38
    There is actually an error, the two 100k divider/+input of the top opamp is connected to between R14 and R15, I will update the circuit when I get home.
    edit:
    Now the circuit is updated, any thought?? As I have no clue.
  6. ScottWang
    Aug 23, 2012
    4,930
    777
    Try to Reducing R17(470),R45(470),R15(1K).
    Before you change the value, you should measure the amplitude of voltage of 12V power line of right side, after you changed them then measure again.
  7. bug13
    Feb 13, 2012
    1,213
    38
    Could you explain why?
  8. ScottWang
    Aug 23, 2012
    4,930
    777
    I rechecked the value of resistors, I think they should be increasing R17(470),R45(470), and reducing R15(1K).
    Why : I just thought if the impedance of cable was increased then the amplitude of voltage will be lower, so if change the value of resistors may changing the amplitude of voltage, if the amplitude too low may not enough capable to drive the TLC2272, and also can't drive the pic.
    When you tried it then tell me what will it be?
  9. bug13
    Feb 13, 2012
    1,213
    38
    For whoever still follow, the problem is from the cable, I tried a different cable but same length, problem solved.
    But be a bad cable, but this bad cable work on other device, just not this one
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Is that the only bug? Why is the +input of the bottom opamp connected to the signal going into the top opamp?
    Isn't the top opamp the receiver, and the bottom one the transmitter? If so, the +input of the bottom opamp should be connected to the 1/2Vdd reference, which is the midpoint of R11 and R12.
    And the wire you added from that point back to R14 is probably wrong too.
    Or maybe I am misunderstanding what the bottom opamp is supposed to do?
  11. bug13
    Feb 13, 2012
    1,213
    38
    I don't know, it could be some errors from the schematic. I knowledge is not enough to tell if there is errors or not, I just copied it as it is.
  12. ScottWang
    Aug 23, 2012
    4,930
    777
    Have you ever measure the impedance of two cables?
  13. bug13
    Feb 13, 2012
    1,213
    38
    No I haven't, but I am going to bring my cheap eBay LRC meter to take some reading tomorrow.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Can you say that the circuit is supposed to be a transmitter and receiver?
    If so, then we can be sure the top opamp is the receiver, and the bottom one is the transmitter. Both should have their + input connected to 1/2 Vdd (mid point between R11 and R12).
    I have coreected the schematic and attached it below. It should work now. :)
