DC power jack shows voltage in 3rd pin when plugged in?
Discussion in 'General Electronics Chat' started by geratheg, Aug 22, 2014.
  1. geratheg
    Jul 11, 2014
    107
    I have a few DC power jacks of various sizes and shapes with 3 pins, 2 of them are connected when not plugged in, 1 is isolated for positive. When a plug is plugged into the jack usually the 2 that were connected disconnect, one goes to negative, the other - which I will call the third pin - isn't connected to anything. This is true for all power jacks and none of them show voltage in the third pin except for one.
    That's strange, where is this voltage coming from to the third pin if the pin is disconnected? Is this something to worry about and should I get a new adapter?
    This is a picture of the adapter that shows voltage, I only have one piece: 5.5mm x 2.5mm DC Power Jack
  2. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    You would need to show all the connections? if only 2 wire DC is used then what is connected to the other jack connection, if any?
    Max.
  3. geratheg
    Jul 11, 2014
    107
    Nothing. I just tested it bare with no circuit. Multimeter straight onto the jacks terminals.
  4. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    If it is not connected to anything why worry?
    It is probably not opening the third pin for some reason.
    Max.
  5. geratheg
    Jul 11, 2014
    107
    Oh I don't know, maybe I should just use it without worry. Third pin isn't going to be connected to any circuit or casing. I really don't know what the third pin is there for? What are some applications of it?
  6. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    It is sometimes used on a power jack socket to disconnect the internal power when the external power jack is plugged in.
    Max.
  7. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    It's for battery power. You connect the positive battery terminal there. The jack automatically disconnects it when you plug in. If you see voltage there, it's broken, but if you don't have a battery or other power source, it doesn't matter.
  8. geratheg
    Jul 11, 2014
    107
    Thank you for the responses. I don't have any use for it, and no longer need to worry.
    As for battery power, it would make more sense to connect the negative terminal of the battery there? Since the third pin is connected to the negative terminal when the power plug is disconnected.
  9. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    Depends which way around you're wiring it! Most devices use a negative tip, if they use batteries.
  10. shortbus
    Sep 30, 2009
    4,092
    1,672
    The jack your talking about is more likely to be an audio jack instead of a power jack.
    The pin disconnecting shuts off the devices internal speaker when an earphone is plugged in.
  11. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    Hmmm, I doubt it. The form factor might be slightly different, but I'd guess the OP is talking about something like this:
  12. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
  13. shortbus
    Sep 30, 2009
    4,092
    1,672
    Didn't see the link to a picture, sorry.
  14. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    The pic displays in the body of the post?
    Max.
