DC power jack pins
Discussion in 'The Projects Forum' started by sportsfan27, Mar 17, 2009.
  1. sportsfan27
    Thread Starter Active Member
    Jan 29, 2009
    43
    What do the pins refer to in a DC power jack (such as this)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    1 is the ring, 3 is the tip, and 2 is the N/C (normally closed) contact. The + symbol indicates that the tip should carry a positive voltage referred to the ring.
  3. sportsfan27
    Jan 29, 2009
    43
    So pin 1 is -, 2 is ground, and 3 is +?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No, the ring will be circuit ground. The 2 - 3 contact is to establish a circuit in the absence of the power plug. There is no firm rule as to the usage of the contact closure.
    In fact, you are free to use the jack in any way that makes sense to you in a circuit. The jack can carry a signal instead of power.
    Here is a link to the plug end - yours will be the TS plug - http://en.wikipedia.org/wiki/TRS_connector.
  5. sportsfan27
    Jan 29, 2009
    43
    Ok thanks-DC inputs are much more different than an AC input.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    It is not a stereo jack. It does not have a ring.
    1 is the sleeve.
    3 is the tip.
    2 is connected to 3 without a plug and 2 disconnects from 3 when there is a plug.
  7. sportsfan27
    Jan 29, 2009
    43
    What about this type?
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Similar, except 3 is a male center pin, and 1 contacts the sleeve.
