DC power jack in OrCad
Discussion in 'General Electronics Chat' started by xiv014, Nov 10, 2010.
  1. xiv014
    Nov 9, 2010
    A question for you OrCad folks out there.
    Is this the correct way to connect the "Conn Jack PWR" symbol? (see the attached image)
    I'm not sure if I should be connecting Vcc to pin 3 or pin 2...
    Thanks!
  2. retched
    Dec 5, 2009
    5,201
    313
    It doesn't matter, but you have to stay consistent.
    If you connect VCC to pin 3, you must be sure the male pin has VCC connected to the corresponding ring.
    You are the designer.
