DC Power Cable Wiring
Discussion in 'General Electronics Chat' started by 123445, Apr 3, 2013.
  1. 123445
    Mar 15, 2013
    18
    Where goes RED+ and BLACK- ?
    - Could someone draw ?
  2. spark8217
    Aug 29, 2011
    64
    Hi
    Im sure if you google what you require there will be lots of clear images to be selected for the application you need.
    cheers
    spark 8217
  3. 123445
    Mar 15, 2013
    18
    "spark 8217" I'm more of an visual people. Some written explanations I have seen but not images on google\altavista\etc... Don't want to blow my PWM-unit PCB :(
    - If you have time mark +,- on photos and upload them on free picture sites like: Photobucket.com, Flickr.com or such...
  4. ScottWang
    Aug 23, 2012
    4,930
    777
    The photo shows that it is a 3 pins stereo plug connector, it's not the two pins for power.
    You can also used it for dual power supply.
    If you want to using for a single power supply that you should be choosing like this page.
    Two wires for plug and three pins for block, you can used it for the power supply or mono headphone.
  5. 123445
    Mar 15, 2013
    18
    OOoppss... Mistake Forget that audio cable below... First picture is the right one in question...
    Bought this:
    [​IMG][​IMG]
    and bought this:
    Now connecting wires problem:
    Where goes red+ and black- wires ?
  6. DenzilPenberthy
    May 28, 2012
    20
    7
    There is no standard way of wiring these power connectors. Some equipment uses the centre conductor as + with the outer as - and some equipment uses the opposite.
    If you are wiring up both the jack and the socket then you can decide for yourself which way to connect it.
    There are three connecions on the socket because it includes a switch so you can detect if a jack is inserted. Plug the jack into the socket and use a multimeter to see which of the three conections is which.
  7. dentedduck
    Apr 3, 2013
    Yes, there is no standard way. One tip you could follow though, is to keep the positive shielded in the center. This way if you happen to drop the plug connector onto a metal table (as we use in optics), you won't short things out. If you don't think that's an issue, then you can go either way. Just be consistent.
    Dave
  8. ScottWang
    Aug 23, 2012
    4,930
    777
    Normally the centre is used for positive, but if this just using by your own then you can define by yourself.
    You can using multimeter set on R range to measure all the pins when you unplug and plug in.
  9. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Center should used as positive. Because it isn't exposed. If the outside of this connector was used as the positive it could easily grounded during insertion, touching the chasse or just hanging free thus damaging the source supply.
