As my username implies...I may be too far out of water. I have located a similar thread, but there was not a response. Here is my simple project goal:
Small DC motor that runs with 6V battery pack. I would like to have one button (when pressed) run the motor CW, stop when released (i think this is a momentary switch?) The second button, when pressed, runs the motor CCW until released. I can easily do this by swapping the terminals on the battery pack, but I am looking for a little more "elegant" solution for integration into an elevator-like toy project that I am building with my 7yr-old. Position of the motor is not required for the sophistication level of this project. Integrating a limit switch to break the circuit at each end of travel is my plan, if I have space. Ultimately, I would like to get to a continuous operation mode (push a different button, device stays on and automatically reverses when it hits the limit) - I'm guessing that there are some relays involved...but I am way outside my wheelhouse.
I apologize in advance if this is not the right forum for this question...and if there is a "cookbook" solution out there, please point me in that direction. I realized after I started into this project that I am essentially emulating a low voltage drill driver that has a forward/reverse button...had I had one to cobble from, I would have started there...I am now looking for some guidance on a shopping list from Radio Shack and a quick schematic....
Thanks in advance for your time and consideration!
