dc ot dc converter
Discussion in 'The Projects Forum' started by sujinvipin, Sep 8, 2011.
  1. sujinvipin
    Aug 18, 2011
    28
    i have a dc to dc converter of 48V input and 24 volt output giving 20 Amp maximum output current , now how can i calculate the current input or drawn by the converter?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    PowerOut = PowerIn / ConverterEfficiency
    Vout * Iout = Vin * Iin / ConverterEfficiency
    24V * 20A = 48V * ?? / ??
    Substitute, isolate the unknowns and solve.
  3. sujinvipin
    Aug 18, 2011
    28
    Shall i confirm with it or is there any better solution
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the problem? Is that too complicated?
    If you don't know the converter efficiency, you will need to calculate it by:
    Efficiency = PowerOutput / PowerInput
    You already know the output power requirement, correct? 24v * 20A = 480 Watts.
    You already know the input voltage, correct? 48V, right?
    So, you need to at least find out one of the two missing variables; input current, or converter efficiency.
    If you don't know what the converter efficiency is, then guess low. Estimate 75% to 80%.
