dc offset
Discussion in 'General Electronics Chat' started by gw95, Jan 28, 2012.
  1. gw95
    Nov 9, 2011
    5
    what is dc offset exactly and how is it applied to electronic circuits?
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    DC offset is a deliberate introduction of a DC level to a circuit to shift its operating point.
    For example, DC offset is applied to transistors to make them work correctly, as well as op-amps for use with a single polarity power supply.
    There are countless other examples, but those are common ones. :)
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    DC offset might be a bad thing sometimes. When wiring an Operational Amplifier, a DC voltage will appear at its output even no voltage difference is applied at its input.
    There are ways to counter that, though.
  4. holnis
    Member
    Nov 25, 2011
    50
    DC offset occurs when hardware,for example, such as a sound card, adds DC current to a recorded audio signal. This current results in a recorded waveform that is not centred around the baseline .
    In some cases, when DC-Offset is present, glitches and other unexpected results can occur when sound effects are applied to the audio file. You can compensate for this DC offset by adding a constant value to the samples in the sound file.
