DC offset is for
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 5, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    What is DC offset for?
    Having extreme DC offsets for each stage is for what purpose?
    A lot of times, multiple stages of op amps don't even have a DC offset on the input or output
    What Purpose is having DC offset on the input or output of op amps?
    I thought DC offset was to not distort or clip off the positive or negative cycle of the waveform
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Dc offset, if designed in, is there to make the circuit work the way it should. Without it, the circuit will not provide the desired function. It all depends upon the next stage and what it expects as a proper signal. This has been discussed before.
  3. DexterMccoy
    Feb 19, 2014
    429
    Yes true i know this
    But why would a stage need a very high DC offset and the next stage need a very low DC offset or change Polarities of the DC offset , one stage is positive DC offset and next stage is Negative DC offset
    I thought DC offset was to not clip off the positive and negative cycles, isn't this true?
    What else is it used for?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    It makes the design engineer a valuable asset to his company. He is the only one that knows how and why the circuit is made the way it is. Job security.
    absf, shortbus and Little Ghostman like this.
  5. DexterMccoy
    Feb 19, 2014
    429
    A DC offset voltage is used for
    1.) To change the Input threshold of the op amps input?
    2.) To change the Zero crossing point of when the input?
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    1.) yes, unless there is a problem with that stage or earlier stages.
    2.) yes, unless there is a problem with that stage or earlier stages.
  7. DexterMccoy
    Feb 19, 2014
    429
    Cause most Op amps inputs and outputs are at ZERO BIAS and start at Zero crossing
    When Op amps that have a DC offset , it changes the starting of the zero crossing point and the inputs threshold
    When you change the inputs threshold voltage , the Input signal won't TURN ON the Op amps input unless it " Exceeds or Crosses" this threshold voltage/dc offset voltage
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    You are describing a comparator when you talk of Turning ON and Turning OFF. In an analog amplifier with moderate gain, the output will rise and fall to values less than saturation levels as the input changes.
    The offset can be used to center the output about zero or to either a positive or negative value depending upon the need of the following stage or the status of the input signal.
    Frequently, since no circuit is perfect, an offset control will be installed as part of the design. That control will allow compensation for component tolerance variations that cause the output to be something other than optimal.
  9. kubeek
    Sep 20, 2005
    4,689
    806
    I think you are mixing up comparators and opamps. Opamps are NOT turned on or off, the should behave linear all the way. Sometimes it is convenient to have base level be at zero, sometimes its not. Could be beacause of the available choice of resistors, or the lack of added resistors in other stages, or a billion other reasons.
    You really need to stop thinking that by analyzing a few ovely complex circuits (that are already severly optimized) down to the very last detail you can suddenly understand everything. It just doesn´t work like that, and the kind of questions you keep asking suggest that you still don´t understand that.
    Start with simple circuits, not with aircraft avionics. Even though those circuits come from the seventies they are really a product of many years of fiddling and optimization, they contain almost nothing that is straightforward and easy to explain and understand.
    shortbus likes this.
Thread Status:
