DC motors
Discussion in 'General Electronics Chat' started by shredability, Jan 16, 2014.
  1. shredability
    Apr 1, 2012
    31
    I'm building a small desktop CNC designed for milling PCB's, I need small DC motors w/ encoders (NEMA17 mounting style)
    I need something like this, but a DC motor instead of stepper motors. I simply just can't get the accuracy from step motors. Brushed motors preferred & they need to be less then $40. I was hoping someone might know about something about this.
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If you are not getting the accuracy you need is this due to the gearing or resolution of the steps to distance, or maybe mechanical deficiencies?
    DC motors are fairly plentiful but you need servo grade with a feedback element of some kind and a drive/controller that has PID control.
    Brushless DC are becoming more popular and replacing the DC brushed.
    Max.
  3. shredability
    Apr 1, 2012
    31
    I'll be building the feedback system and writing my own PID libraries using the encoders and driving the motors with an L298 H-bridge. I haven't tried with stepper motors yet but typically they're only 1.8deg/step and I'm not a fan of the open-loop factor, especially if the system may be loaded
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I doubt you will find the motors you want for that price. Last time I bought servo motors for a CNC machine the price was north of $2500.00, with servo amps that took ±10V input and output ±300V.
    Stepper motors can be half stepped and drive an ACME leadscrew with an anti-backlash nut to achieve resolutions on the order a mil. As long as you ramp the velocity up and down through the mechanical resonance and stay away from the electrical resonance you can engrave expensive silver anniversary trays without worry.
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If you want more details on this application you are using, have you looked at the CNCzone site?
    Max.
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    They can be "micro-stepped" too, down to 1/16 reliably. I've heard some going to 1/32 and reporting no issues, but I don't trust that. Some drivers support all the way down to 1/256 microstepping, but that's probably laughably unreliable.
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    strantor likes this.
  8. atferrari
    Jan 6, 2004
    2,663
    783
  9. strantor
    Oct 3, 2010
    4,302
    1,989
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Microstepping is different than half stepping. In half stepping on a 4 phase motor you alternate 2 phases on / one phase on. In micro stepping you are actually playing with discrete levels rather than just a binary on-off.
    So half stepping a 1.8° stepper motor with a lead screw pitch of 2.5 turns per inch gives 1000 steps per inch or .001" per step.
  11. shredability
    Apr 1, 2012
    31
    You can half step a motor with only two phases
    Where C = -A & D = -B
    Something like this would be ideal, just w/ the n17 face plate. Something like this must exist.
    http://www.pololu.com/product/1442
  12. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    If you have the motors sized right and the right drive, and you eliminate mechanical inaccuracy, then it the only thing left is the linear resolution equal to one step.
    What is it, and is this resolution accurate enough?
    Max.
  13. GopherT
    Nov 23, 2012
    6,303
    4,019
    What is the application and what accuracy (resolution) are you looking for?
  14. shredability
    Apr 1, 2012
    31
    I'm building a cnc machine, but the real purpose of the project is a motion controller. Its a DC brushed servo controller, so steppers are out of the question.
  15. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    So is this a controller such as an intelligent drive where the PID loop is closed in the drive, or does the loop go back to a trajectory planner/controller?
    Max.
  16. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Try holding a brushed dc motor still. Nice thing about steppers is that they can be held at torque. Regardless of your loop's capabilities, your resolution is only as good as your commutation, typically much worse than a stepper.
  17. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I generally use 2500p/rev encoders, with the x4 factor, this translates to 10,000counts/turn, I can position to 1 pulse, with both DC brushed and BLDC.
    This is using Galil motion cards with torque mode drives.
    Max.
  18. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yeah, I'm one of the guys who designs microstepping drivers. ;)
    A microstepping driver can function at 1/256th stepping, which was actually the last one I designed.
    The two main problems are; the motor's step accuracy which can vary from step to step.
    And of course the main problem is the load deflection, as the position of a stepper motor depends on load torque. It is held in place by magnetic "springs" as as load torque is applied the rotor deflects further and further from the original position. If deflection becomes large enough the motor will "jump" to the next pole position which is generally 1/50th of a rotation (on a 200 step/rev motor).
    To Shredability; A size 17 stepper can be bought as 400 step/rev (0.9 degree) and be driven very well with 16th microstepping giving positioning ability to 1/6400th of a rotation (plus or minus a couple of microsteps depending on load torques).
    They can be very reliable if you don't exceed load torque which comes down to good machine design.
    Total cost about $17 for a motor and maybe $20-$30 for a decent microstepping driver IC module. Cheaper if you buy a PCB that will drive 3 or 4 motors.
    If you choose to go with a DC motor and encoder, firstly you won't get a motor with encoder for $40, not even close. Your brushless 2-phase driver will be expensive and a hassle to design. Your encoder won't give 6400 steps per rev. And even if you paid extra for a fine resolution encoder like that it would be very difficult to get it to hold that position anyway.
    So even after much greater cost and enormous effort you probably won't get as good a performance as a cheap stepper setup anyway.
    Just go with steppers and avoid stupidly high load torques and fault torques. :)
  19. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I don't quite understand that? I can hold position to much finer resolution than that, and in fact industrial encoders now go up to 100,000 counts/turn.
    Max.
