dc motor
Discussion in 'General Electronics Chat' started by danebrown.sjce, Dec 2, 2013.
  1. danebrown.sjce
    Dec 2, 2013
    14
    i need a small motor(im confused whether to choose stepper ot dc motor i also have heard of 6mm coreless motor) i need motor wic can run on 3-5 volts less current with small size....motor has to drive minimal load ...pls suggest the type of motor and its availability
    size is the most important criteria ....
  2. shortbus
    Sep 30, 2009
    4,092
    1,674
    And we're confused as to what size you need the motor to fit into, what the minimal load actually is, and what the application is the motor is expected to do. More real information will get better results.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    "small" or "minimal" isn't detailed enough for you .. :p geesh so demanding.. :D
    shortbus likes this.
  4. danebrown.sjce
    Dec 2, 2013
    14
    motor has to mov a hollow cylinder up down ....hollow cylinder dia = 2mm length 10mm .....
  5. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Weight of cyclinder? rate of acell/decell? Precise positioning required? point to point or various precise positioning?
    I don't have a listing for "Minimal Load"?
    Max.
  6. danebrown.sjce
    Dec 2, 2013
    14
    weight =3g
    i want to move the cylinder up and down ,controlling the motor by a micro controller ( reciprocating motion)
  7. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    But by precise positioning via feedback or will point to point via limit switch do?
    If you want to conserve current as much as possible, do not go stepper.
    Max.
  8. danebrown.sjce
    Dec 2, 2013
    14
    point to point no feedback required .
    actually what im doing is a braille display . each braille character has 6 dots . im actuating
    each dot by a motor . i need a motor to serve this purpose.
  9. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Wouldn't this constitute variable (non-repetitive) positioning?
    IOW each dot a different position?
    Or is this just the move on the detection of a dot?
    Max.
  10. mcgyvr
    Oct 15, 2009
    4,787
    973
    IMO. a motor is a poor choice for that intended function..
    A push/pull solenoid is a better/easier solution.. no need to convert rotary to linear motion either..
    maybe a piezo actuator / voice coil
    MaxHeadRoom likes this.
  11. danebrown.sjce
    Dec 2, 2013
    14
    @MaxHeadRoom
    i planned to use 6 motors for 6 dot. There will be 6 circular openings on the surface. each time a dot is actuated cylinder emerges out of the circular opening.
  12. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Now the application is a bit clearer, I agree with Mgyver a linear actuator may be the answer as it sounds as if you will need to go rotary to linear anyway?
    Dot matrix printer style and the old paper tape punch?
    Max.
  13. danebrown.sjce
    Dec 2, 2013
    14
    ya i have to convert rotatory to linear motion.
    Its dot matrix style .
  14. danebrown.sjce
    Dec 2, 2013
    14
    i will try both motor and solenoid (if i get a solenoid with operating voltage 3-5v ,small size and less delay).
    so with motor what are my options (which motor do u suggest??).
    with solenoid ??
  15. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    There are many small DC motor available on ebay around that voltage.
    But the solenoid would be my first approach, if you can find an old paper tape punch it sounds like that would be ideal, but the 3-5v makes it a bit restrictive, especially with 6 operating at once?
    What kind of power source are you designing around?
    Max.
  16. mcgyvr
    Oct 15, 2009
    4,787
    973
    There are hundreds of motors that "might" work..
    But obviously without knowing the mechanical design of how to intend to connect these to the dots its impossible to recommend a suitable motor or even a solenoid.
    A google search for "5v solenoid" will turn up TONS of products that might be used..
    But again.. there are many details that are missing from your question.. and IMO are up to YOU to figure out and define..
  17. danebrown.sjce
    Dec 2, 2013
    14
    power supply 5v, 500mA.
  18. danebrown.sjce
    Dec 2, 2013
    14
    thank you all for your help !!!!! :)
