DC motor speed controller Output 0-180VDC
Discussion in 'General Electronics Chat' started by karke034, Mar 25, 2010.
  1. karke034
    Mar 24, 2010
    I bought production- lathe BERNARDO Profi 300 in Wiena into the KFZ-Meisterbetrieb Effingerrrgasse 31 shop.
    When I put lathe in electricity the fuse burn out.On the PCB - DC MOTOR SPEED CONTROL I found forgotten metal pad, which cause the damage known as «short circuit» . The transistor(or voltage regulator) blown, as you can see on the picture( the transistor or voltage regulator is marked).The markings of the elements are intentionally removed. I need a label burning electronic elements for repairs controler.
    Please, help me if you can, because my lathe doesn’t work.
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    I have used this control before for DC motor control. It is manufactured by KB Electronics in Cape Coral, Florida, USA. See www.KBelectronics.com.
    Cheers, DPW [ Everything has limitations...and I hate limitations.]
    karke034 likes this.
  3. karke034
    Mar 24, 2010
    Thank you Mr Wetick. I need a label burning electronic elements for repairs controler, or electric scheme.
