Dc motor reversing +override
Discussion in 'General Electronics Chat' started by jerrymyersmills, Apr 22, 2011.
  1. jerrymyersmills
    Mar 22, 2011
    29
    I want to reverse a dc linear actuator hourly.
    I want a time period of one hour between reverses.
    I am thinking of using a DPDT relay timer for the reversal but ia m a bit confused about the wiring ; it is pretty confusing.
    Subsequently,i want to install an over switch to enable me test if the actuator is in working condition .
    Any clues?
    MILLS
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    If you are not the same person who posted a nearly identical question in the projects forum, then refer to this; speak up if that doesn't answer your question.
  3. jerrymyersmills
    Mar 22, 2011
    29
    No i did not post it, i joined the forum about 3 weeks ago !That post very similar to mine;but in the latter case there is no override.
    The actuator is 12VDC and the actuator is also 12VDC.At the same time i want install a DPDT override switch.Any clues.
