DC Motor replacement troubleshooting
Discussion in 'The Projects Forum' started by droggie, Dec 25, 2012.
  1. droggie
    Oct 21, 2012
    137
    I want to replace the motor on the left with the motor on the right. However it does not seem to run when I connect it to the battery plate pictured. There is switching a mechanism within in the device; it is that long piece of metal attached to the plate. I tested this motor on breadboard with a 9V battery and it worked fine. Any suggestions? How can I test the battery plate?
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    Solder the wires to the motor then..
  3. droggie
    Oct 21, 2012
    137
    The plates do not take the solder...should I try silver solder?
