Dc motor >> Question
MaxHeadRoom
Joined Jul 18, 2013
28,702
What data sheet, they are from China!
25mm that is a small motor, and it does not state the GB ratio?
8Kg-cm I would say is the GB output torque.
Max.
THE_RB
Joined Feb 11, 2008
5,438
They usually quote the "best possible scenario" specs, it's a marketing thing.
So the max torque would be a final shaft torque, at stall.
The "600 RPM" speed would be a final shaft speed (after gearbox) and is most likely the no-load speed as that is higher (and easier to measure) than a rated-load speed.
