can v interface dc motor to 8051 without ic drivers?
K Thread Starter kanasu Joined Jul 22, 2014 2 Jul 22, 2014 #1 can v interface dc motor to 8051 without ic drivers?
mcgyvr Joined Oct 15, 2009 5,394 Jul 22, 2014 #2 http://www.8051projects.net/dc-motor-interfacing/introduction.php You want some sort of h-bridge.. That could be made with transistors/mosfets or a dedicated hbridge IC.
shteii01 Joined Feb 19, 2010 4,644 Jul 22, 2014 #3 kanasu said: can v interface dc motor to 8051 without ic drivers? Click to expand... You can, but there is not enough current to run the motor. So, if you want motor that does not run, just sit there looking pretty, then connect it directly to 8051.
MaxHeadRoom Joined Jul 18, 2013 28,617 Jul 22, 2014 #4 For uni-direction then only a single Mosfet is needed. Max.
