dc motor/generator
Discussion in 'Homework Help' started by suzuki, Oct 13, 2011.
  1. suzuki
    Aug 10, 2011
    119
    I'd to get some more information on the torque/speed characteristic of a dc motor that is being used as a generator.
    i know that torque is >0 and decreases linearly as speed is increased (positively) in a motor. in the generator mode, is it the torque or the voltage that will be negative? is there such a plot of torque speed that has all 4 Cartesian quadrants to show this?
    I'm asking this because in a lab experiment, i found that when i supply a rectified ac voltage to the dc machine, it is motoring and spins clockwise. however, when in apply some positive dc source (to the load) the direction of the spinning is now counterclockwise. So I suppose where i am confused is, since the speed is now negative, does this indicate that we are in the generating mode? I'm not certain since I thought it would be possible to get this rotation by just switching the leads (reversing the polarity) of the input supply.
    tia
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps if you post a diagram of your experimental setup it might be easier to understand the questions a little better.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    If you are using the motor as a generator, why would you apply any voltages to it's leads?? If a motor is used as a generator, you are supposed to spin the shaft, and get power out of it.... the output would be alternating so you would have to rectify it.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    What BMorse said, + it will only work if it is a permanent magnet motor. If it is a wound field then you have to supply current to the field.
    When you were supplying rectified AC, if you had reversed the leads, it probably would have reversed direction just like reversing the leads with DC. That is, unless it is a series would motor, in which case it should always spin the same direction (AC or DC) until you reverse the field winding.
  5. amilton542
    Nov 13, 2010
    494
    64
    suzuki likes this.
  6. suzuki
    Aug 10, 2011
    119
    the link to the four quadrant operation was exactly what i was thinking of, thanks!
