DC Motor failed to run on load
Discussion in 'General Electronics Chat' started by leendabests, Aug 29, 2012.
  1. leendabests
    Aug 29, 2012
    Im using DC motor to run the conveyor but suddenly the armature shows high current 130 A for 30 V power and the speed cant increase anymore. The motor power stated in the name plate is 93.8 KW, Armature voltage is 453 V and Armature ampere is 225 A. The motor can run free load after disconnected from the load but fail to run on load. We have checked the field coil, armature coil and the brushes . The are no insulation damaged since it can be run free load.
    What are the possible causes to the motor that fail to run on load? Is it because not strong magnetism or another mechanical failure?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I moved this thread to a more productive area, where you are likely to get better answers.
  3. mrmount
    Dec 5, 2007
    59
    7
    Why are you running the motor @ 30V when the name plate says something different ?
  4. PackratKing
    Jul 13, 2008
    850
    216
    Can you put up a picture of the motor nameplate ?? mrmount is right......that sounds an awfully big motor to be running @ 30 volts
    Have you run all the coils and the armature / commutator you listed with a Hi-Pot to frame ? That will show any coil / insulation shortfall that other testing does, only without totally destroying the bad area, leaving some options for repair.
    I have had the privledge of rebuilding large air conditioning motors for the D&H Railroad.
