DC motor Driver
Discussion in 'The Projects Forum' started by ajitnayak, Jan 29, 2014.
  1. ajitnayak
    Feb 22, 2013
    Dear all,
    I am looking For Dc motor Driver circuit which can handle 24v 16A-20A. with back emf and over voltage protections. Can someone here help me out building it
    We can use DPDT relay/spdt relay or Motor Driver ICs Must have protection and compatible with Arduino boards.
    it must have feature like
    dir change
    on/off the signal
  2. THE_RB
    Feb 11, 2008
    The feature you requested; "direction change" means you should google for a "h-bridge DC motor driver". :)
    That will be slightly more expensive than the common "DC motor PWM driver". You could always buy one of those and add a direction changing relay.
