I have come across this circuit for a simple dc motor control. Does anyone have any input. I need something simple for speed control. high precision is not needed. Thanks.
It is a 90 volt dc dayton motor. I do not have the current requirements with me. I was going to use it on a grinder in a home shop. Why "very dangerous"
Check post by hobbyist, right now two posts below yours. He is using 90V PM motor with a SUS trigger; schematics almost the same. The DIAC will trigger at about 28V & SUS adjustable, as shown about 10V. An isolation transformer will keep from having a " hot chasis".
I hope this is a better image. My motor is a 90volt 1amp continious duty permanent magnet motor. This circuit came from "The Home Shop Machinist" Charles Eyer 1996. The idea was to use a dc lawnmower motor on machine tools for speed control instead of belts. I was wondering if it still is viable or is there another equally simple cuircut that can be used?
The circuit is simple & should work. I would connect motor to moving SW contact, fixed to R2 & B1+, other SW to black 115 AC line along with a 10A fuse. Ground motor frame & chasis if metal. Remember all of the accidents back in the 1950s when when we had high V series string filaments & hot chassis; be carefull if not using isolation transformer.
Not pretty, but I hope it helps: The transformer willnot make ckt work any better, but adds a bit to safety, @ 150W, probably expensive. There are a lot of appliances that use two wire cords & no transformers, but are designed to keep wandering fingers away from hot circuits.
