i want to control DC motor using pic microcontroller. anybody help me to do this. i code in mikro c
R Thread Starter RustamJaved Joined Apr 30, 2009 2 Apr 30, 2009 #1 i want to control DC motor using pic microcontroller. anybody help me to do this. i code in mikro c
AlexR Joined Jan 16, 2008 732 May 1, 2009 #2 I'm sure there are many people on this forum who will glad to help but no-one here is going to write the software for you. What you need to do is research PWM (pulse width modulation). Do a google search on PWM motor control. Then, select a PIC that has a PWM module. Read the data sheet so you understand how PWM works on the PIC. Design your circuit and write your code. If you run into any problems we will be happy to help you but we will not do your work for you.
Tahmid Joined Jul 2, 2008 343 May 2, 2009 #3 Hi, I can provide you the diagram and code for dc motor control.But the code will be in Assembly and the Pic will be 16F877A. If it fulfill your requirement,please let me know and I will upload it for you. Thanks.
