DC motor Control Progressive Start and Stop
Discussion in 'The Projects Forum' started by Nara Shikamaru, Jul 27, 2008.
  1. Nara Shikamaru
    Thread Starter Active Member
    Nov 24, 2007
    92
    hey Everybody!!.....
    I`m stck with the Control of a DC Motor....I need To Control a DC motor in this way, it Must Start real slowly, and then progressively but slowly should continue to reach its maximun velocity, it could take up to 1 min to reach it; then remain for a set time stable at its final velocity and after the time pass then start to slow down in the same opposite slowly way as the start........how would i do that??
  2. scubasteve_911
    Dec 27, 2007
    1,202
    You need what is called a trapezoidal or s-curve motion controller. You can accomplish this by :
    - writing code to a microcontroller that takes encoder feedback and controls an h-bridge via PWM or linear control
    - using an asic and running it with the pc or a micro
    http://www.national.com/pf/LM/LM629.html
    - analog circuit methods..
    Steve
  3. scubasteve_911
    Dec 27, 2007
    1,202
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    You might also want to search on "soft-start" for motor controllers for other ideas. John
