DC motor, consistent speed under different loads?
Discussion in 'The Projects Forum' started by diy549, Jul 9, 2009.
  1. diy549
    May 16, 2009
    11
    Hello All, Is there some way to get a Dc gear motor to run at the same speed even under slightly different loads?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    There is - depends on the approach you choose, of which there are several - probably boils down to complexity / cost in the end according to your requirements.
    For example the motor control in the following link uses the motor back EMF to sense & control the speed under varying loads.
    http://www.siliconchip.com.au/cms/A_110145/article.html
  3. diy549
    May 16, 2009
    11
    do you know where I can purchased a controller like the one above. Thats exactly what I need.
