Hi to all, I've just joined this forum and know nothing about electronics but hopefully I can learn something from you guys and gals
I'm just dabbling with the very basics so please forgive me when (not if) I ask dumb questions... here goes..
Ok, I've got this small 'can' type brushed dc motor to play with and there is no information stamped on the barrel, at all, ie voltage required or current rating. I have used a 6v 6ah lead acid to power it up and it seems ok, but I don't know if a 4v 9v or 12v would be a better power plant for it, Is there a way of determining the ideal voltage for this motor without buying several batteries and trying them all.
I have put a multimeter on the set up which is showing 1.57 ah draw.
Any advice would be much appreciated but please be aware that if you make it too technical for me I'll pester you for more advice!!
Many Thanks Lecron
Many Thanks Lecron
