DC motor - attach something?
Discussion in 'General Electronics Chat' started by Captain E, Jun 25, 2015.
  1. Captain E
    Jun 16, 2015
    81
    6
    Hi!
    On all the dc motors I have, the rotating "sticks" are different sizes and shapes, some hexagons and some completely round.
    How can I attach something that not normally fits there? For exemple a gear to the round stick of the motor?
    Glue? Soldering?
    What about a metal stick to a plastic gear?
    Thanks!
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I haven't a clue what you are referring to ??:rolleyes:
    Max.
  3. djsfantasi
    Apr 11, 2010
    2,911
    881
    He has or has seen motors with a variety of differently shaped axles. Some circular, some hexagonal, etc... These he calls "sticks"; I'd call them axles. He wants to know how to attach something to them, like a wheel or gear.
  4. WBahn
    Mar 31, 2012
    18,089
    4,917
    MOD NOTE: No indication that this has anything to do with automotive discussions. Moving it to General Electronics Chat.
  5. Reloadron
    Jan 15, 2015
    1,055
    275
    I call the rotating part extending from a motor the shaft. The shafts are generally round and come in a variety of diameters. The shaft can be adapted to a variety of drive fixtures like a sprocket for a chain drive or arbors. You want a gear? Buy a gear with the diameter you want for the shaft size you have. Determine your gear pitch and pressure angle and motor to drive it.
    Ron
  6. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    The common industrial method for coupling using the motor shaft is a straight key or woodruff key, a coupling of some kind is often used, spider, bellow type, all depends on the load and whether backlash is allowed.
    NO glue, soldering or other superficial methods.
    Plastic gear is prone to wear.
    Check out Misumi products for couplings etc.
    Max.
  7. Captain E
    Jun 16, 2015
    81
    6
    Thanks a lot for the helpful informations guys! Yes, I seem to call them "sticks" haha I havn't found an "official" name for them :p
    I didn't know about straight/woodruff keys or any of the coupling methods. Now I know, and I will now try to find where I can get them locally ^^
    Thanks again!
  8. blocco a spirale
    Jun 18, 2008
    1,461
    370
    It depends on the size of motor, you are unlikely to find a woodruff key on a small DC motor. Plastic gears and pulleys are likely to be an interference fit and metal components will probably be secured by a small screw.
  9. Captain E
    Jun 16, 2015
    81
    6
    Okay, thank you :D
