DC motor application
Discussion in 'The Projects Forum' started by Francoisdut, Feb 23, 2009.
  1. Francoisdut
    Feb 23, 2009
    Good day
    I need to design a circuit that needs to do the following: it must be a bidirectional dc motor speed controller using a lm35 temperature sensor as reference for the speed of the the DC motor.
    Any help or suggestions will help.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    What must happen ?
    What is the LM35 used for ? Temperature measurement ?
    What is the relation between temperature and motor movement ?
    Greetings,
    Bertus
  3. Francoisdut
    Feb 23, 2009
    The LM 35 is used for measuring temperature. When the temperature increases the speed of the motor must also increases. The motor must also be able to turn forward and backwards with the use of a switch.
    Greetings
    Francois
  4. KMoffett
    Dec 19, 2007
    2,584
    234
