Solar panel(s) cannot supply a large momentary current;they are very current-limited, and normally operate such that their peak current equals their average current, as in charging a battery.Hmm. The explanation in the link hasn't helped me much.
Sorry I don't really understand.
Yes a DC Link capacitor refers to the capacitance on the DC bus in a motor drive in which you convert the fixed frequency AC input into a DC voltage that is fed to the inverter in your example circuit, the output of which will be a variable frequency AC.Ok. So if I understand correctly, for the example of an smps. When the gate switches at the output side open and close really fast the current spikes and in order for there to not be a voltage dip the capacitor helps to maintain the voltage? Such as the capacitors below?
Apparently I've been using Link Capacitors in vacuum tube guitar amplifiers for over 40 years. In the course of doing that, I also found that polypropylene film capacitors are rather good at their job.We use DC link capacitors in high energy 600vdc+ plasma generation protection circuits.
"A capacitor is a capacitor is a capacitor..."... I also found that polypropylene film capacitors are rather good at their job.
Yep. And they all have the same dielectric absorbtion, DC leakage characteristics, temperature coefficient, price per uf, uf per cubic inch, and self healing properties as each other."A capacitor is a capacitor is a capacitor..."
We know what you mean but 'Capacitance' is capacitance is capacitance. A capacitor is a physical device with many properties other than pure capacitance."A capacitor is a capacitor is a capacitor..."
by Aaron Carman
by Aaron Carman
by Jake Hertz
by Duane Benson
