I am using 3 solid state switching relays to map RGB LED s strips from a control source
to another 4 sets of RGB LED strips. The relay ouput side is separately powered at 12VDC, 4A,
I cannot tap directly to source strip control circuit because it is already near power capacity.
The SSrelay draws 6ma at 12VDC input. The SSrelay will operate
at a voltage range between 3 and 30VDC. The output side can handle 60VDC, but in this
application is 12VDC.
The RGB LED Strip control source provides fade (likely capacitor driven) between color changes, thus there
is a voltage reduction where the SSrelay will continue to operate way too long when it would be best
to be not active. The SSrelay will remain operating at 1 to 1.5 volts when started/operated by a higher voltage.
I need to cutoff the SSrelay input votage at say anything less than 10 or 11 VDC.
I can add LED fade on the relay output side with added electrolytic capacitors if I can stop the relay
from operating during the source fading.
Is there a simple solution? The control circuit must not be affected by this add-on circuit beyond stealing
a small bit of power.
