Hi guys
I want to build a high voltage source it should be around 40kV (several Volt ripple pot. is perfect) ~100um current. These are not exact values but the important point is how to build it in a smaller size?? We have build one for a school project with my adviser. It was around ~10kV with ~10V ripple. So I have some ideas how to generate such a high voltage but they need generally very big size transformer, capacitors etc. using a cascade multiplier circuit. I saw a product of amptek generating 50kV for an X-ray radiation source and it is very small (2.5cm x 5cm x 15cm including the x-ray tube! ). How this can be achieved? I mean do they use a different method instead of voltage multiplier? And what type of components do they use to put them into such a small size box?
Here it is:
http://amptek.com/products/mini-x-ray-tube/#4
My question is especially about keeping the size small ...
thanks in advance!
Here it is:
thanks in advance!
