dc generator not builing up
Discussion in 'General Electronics Chat' started by gjo, Jun 13, 2013.
  1. gjo
    May 22, 2013
    28
    Why doesn't the DC generator build up , if it's output I'd short circuited
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Maybe it's broken.
  3. wmodavis
    Oct 23, 2010
    737
    150
    Build up???
  4. gjo
    May 22, 2013
    28
    Build up, I mean build up generator fields so the generator can produce rated voltage
  5. Dodgydave
    Jun 22, 2012
    5,147
    769
    Is it an auto dynamo, what happens when the field and dynamo output are connected together, it should self excite to full voltage?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Is the question referring to the failure of a self excited DC generator to self-excite with the output shorted. I would have thought that self-evident.
    DerStrom8 likes this.
  7. JDT
    Feb 12, 2009
    658
    85
    This relies on some residual magnetism in the armature. If it hasn't been used for a while this may have faded away. I'm not an expert on this but I think you have to apply some current through the armature windings (by connecting a car battery) to re-magnetise.
  8. Ramussons
    May 3, 2013
    562
    92
    ...... and just make sure that the battery applies the current to the armature in the right direction, else you'll back to square one.
    Ramesh
  9. shortbus
    Sep 30, 2009
    4,094
    1,676
    I think it's the fields not the armature. In the old days we "flashed" the field terminal on the regulator when replacing a generator. Flashed meant to short between the battery and field connections. The fields are the 'magnet' and the armature is the power producer.
