DC generator/motor in a Car
Discussion in 'The Projects Forum' started by jabable, May 12, 2014.
Thread Status:
Not open for further replies.
  1. jabable
    May 12, 2014
    My friend and I are currently working on a automotive project. We are completely stripping down a car in order to rebuild the frame and mount jet engines on it. We have reached a problem with the electricity. The car has no reverse with a jet engine, so we decide that connecting a motor to the differential should work. We still need power for the ignition system and charging the battery. Is there a way to use the motor as a generator as well and if so how? Would it be better to use the motor exclusively as a motor and charge the car at home?
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    Did you read the Terms of Service? A link is provided near the bottom of every page. In particular, this thread might be closed based on the following clause.
    6. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    What djsfantasi said.
Thread Status:
