DC filter for motor with shunt for oscilloscope
Discussion in 'General Electronics Chat' started by singular, Dec 19, 2009.
  1. singular
    Dec 19, 2009
    conecting a oscilloscope to the shunt in a dc 3v motor circuit gives me to much noise in the graph, any idea in proper filter to use?
    I need to check the diference in force between the two parts of a non simetrical pulley and that is the way i feel easier to take the time, rpm, position, etc.
    In the same circuit I took a photocell to check through the B channel on the osciloscope the positions of the pulley and that is working perfect.
    Thanks for advice,
    Luis.
  2. Bernard
    Aug 7, 2008
    4,240
    414
    I would first add a .1 uF cap across motor; still to much hash?, add an RC filtar across " shunt", something like 1k ohm & 1.uF, measure across the .1uF.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yep, you basically need a low-pass filter.
    But if the values of R and C are too large, it'll have a heck of a phase shift.
    This may very well be too much:
    but it's the general idea.
    Reducing R1 and C3 will reduce the shift.
