DC Fan noise issue
Discussion in 'General Electronics Chat' started by nickagian, Feb 18, 2016.
  1. nickagian
    Thread Starter Active Member
    Mar 12, 2010
    34
    In order to cool a telcom device I am using 4x 12Vdc fans from Delta Electronics (the exact type is FFB0412VHN-F00). The fans have a 3-wire interface and I operate them by sending PWM pulses at their power supply wire. The pulses are generated from a PIC-microcontroller and are "converted" to 12V pulses through two FETs (see attached schematic).
    The issue is that the fans seem to disturbe the 12V power supply and as a result they generate several different problems, like bit errors at the transmissions etc, which seem to disappear when I remove the fans. A logical thought was that the pulse current drawn periodically from the fans is causing small dips in the power supply and I was able indeed to verify that with an oscilloscope. Therefore I built an LC low-pass filter in order to make the 12V quieter. And it seems to work when the duty cycle of the PWM pulses is low.
    What however I still not understand is that when I give full power to the fans (the duty cycle is 100%) then I still have the same problems as before. And that actually still puzzles me because at full power there are no pulse currents drawn from the 12V... I have a feeling that the filter has worked at low duty cycle values because it creates an additional voltage drop and thus the fans receive a lower rms power supply.
    Does anyone have any idea on what to do?
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I've responded on the ETO forum.
  3. Sensacell
    Jun 19, 2012
    1,183
    276
    While applying PWM to a Brushless DC fan can create some additional noise, be aware that the internal commutation circuitry also generates pulses of current even when running from steady DC.
  4. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    I agree with @Sensacell you may be applying PWM to a fan that already has internal PWM such as TC653.
    Max.
  5. nickagian
    Mar 12, 2010
    34
    This is definitely not the case! This fan (FFB0412VHN) doesn't have internal PWM.
    Well, I guess that's why I still have disturbances when the fans run from steady DC. Any idea on how to block these pulses disturbe my power supply? What would the frequency of these pulses be in that case?
  6. Kermit2
    Feb 5, 2010
    3,849
    965
    You said it was telecom equipment. Does it not use 48 VDC?
  7. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    That appears contrary to what the spec sheet says, it shows the motor as a BLDC, which requires commutation and also shows an internal driver IC.
    Spec is 2ph 4 pole BLDC.
    Max.
  8. mcgyvr
    Oct 15, 2009
    4,789
    975
    Not all does..
    Some 5, some 12, some +24 (cellular) and most 48 (-48 actually) and even some 130V (utility,etc...)
  9. ronv
    Nov 12, 2008
    3,398
    1,455
    A picture of your scope may be useful.
  10. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Even better, can you put a small current-sense resistor in the ground leg of the motor and show us a scope shot of the voltage developed across the resistor, so that we have some idea of the current pulses produced during commutation?
