DC DC switching regulator
Discussion in 'General Electronics Chat' started by ManeeshaN, Apr 29, 2010.
  1. ManeeshaN
    Feb 17, 2010
    8
    hi ,
    I am using a switching regulator to convert 15V to 5V.
    can someone please tell me the formula to determine the power consumption of the switching regulator.
    its urgetn.
    thanks in advance.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Its 15V times the input current.
  3. ManeeshaN
    Feb 17, 2010
    8
    and how do you arrive at that..
    dont we need to do somthing like in linear regulator:
    (Vin - Vout)* Iout
    oe dont we need to consider efficiency of the regulator for this..?
  4. mik3
    Feb 4, 2008
    4,846
    63
    I told how to calculate the total input power to the converter.
    If you want to calculate the lost power in the converter then:
    Lost power=Vin*Iin-Vout*Iout
  5. ManeeshaN
    Feb 17, 2010
    8
    yes I think there I am,..
    Pin-Pout is the power consumed by the regulator..
    but if i calculate(Pin-Pout)/Pin what do I end up with..?
  6. mik3
    Feb 4, 2008
    4,846
    63
    It is not the efficiency but it can be used as another way to measure efficiency. It will give you the ratio of the lost power according to the input power.
    Efficiency equals Pout/Pin.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I would say Pin = Pout / efficiency factor.
    Pin = Iin * Uin
    Pout = Iout * Uout.
    The efficiency factor can be between 0.8 (for a poor DC / DC converter)
    and 0.95 (for a reasonable DC / DC converter)
    Bertus
