DC-Dc SSR vs High side Mosfet
Discussion in 'General Electronics Chat' started by shortbus, Jan 30, 2016.
  1. shortbus
    Thread Starter AAC Fanatic!
    Sep 30, 2009
    4,088
    1,667
    Can a DC-DC SSR be used in place of a a high side mosfet switch in a circuit? Which one is capable of switching faster, SSR or high side mosfet? I know if the parts would need to be bought the mosfet route would be more cost effective, but I already have the SSR, from another project. The load will be a capacitor bank instead of an inductive or resistive load.
    The SSR is like this one - http://www.ebay.com/itm/Solid-State...c09e389&pid=100276&rk=1&rkt=4&sd=170961637557
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,683
    1,295
    Yes. Many DC-output SSR's use a power MOSFET for the switching element. If the input is fully isolated from the output, then it should work for you..
    ak
    shortbus likes this.
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
    Here is the datasheet for FOTEK SSRs; the DC-DC units are a couple of pages in. Note that the switching speed is listed as 1ms. I would guess that an SSR would be slower than a directly gated MOSFET due to the delay introduced by the optocoupler in the SSR.
  4. David Knight
    Aug 4, 2015
    26
    5
    1ms switching speed is really slow for a dc-dc converter. a high-side MOSFET can switch in a few nanoseconds with a good gate driver.
    An SSR used in a dc-dc converter would have to operate at very low frequency, which would require large inductors and capacitors. It seems like this would be an expensive and bulky solution.
    Note that when charging a capacitor bank, it's important to use current feedback to limit the current to a level that your power source, wires, and circuitry can handle. Without a current limiting mechanism, expect to let out the magic smoke.
  5. Sensacell
    Jun 19, 2012
    1,183
    276
    SSR's are not design optimized for speed, they are more than 10 X slower than a typical switching FET.
    They are optimized for simple floating drive, high voltage and current.
  6. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    I agree with the others. Quoting the specs in the listing, "On-off Time: ≤ 10mS". When the units quoted are mS, that's a sure sign that the switching time is not in microseconds. For a switching converter, you will generally want an turn off time of just a few microseconds at most, and more likely, a fraction of a microsecond.
    The good news is that for the price of that solid state relay, you can buy a regular mosfet, and drive it with a pulse transformer, or capacitively coupled, or by some other conventional means, and still have a few coins left over.
  7. shortbus
    Sep 30, 2009
    4,088
    1,667
    From all the stuff on the web, the old style DC-DC SSR were speed limited, to ~200Hz. The newer ones are/seem to be able to do up to 20kHz for motor PWM drives.
  8. AnalogKid
    Aug 1, 2013
    4,683
    1,295
    There is nothing in post #1 about the application being a DC/DC converter or needing any particular switching speed.
    ak
  9. shortbus
    Sep 30, 2009
    4,088
    1,667
    You correct it's not for a DC-DC converter. It's for my ongoing electrical discharge machine. Was just thinking out loud. Thought if they, the SSR, would work, it would eliminate - 2 mosfets, a few resistors, a diode 2 caps, and a gate driver IC needed for a high side switch. Don't know how the DC-DC converter came into this?
  10. AnalogKid
    Aug 1, 2013
    4,683
    1,295
    Post #1: "Can a DC-DC SSR..." misread.
    For bulk power switching with relatively low frequency power cycles, should be no problem
    ak
  11. crutschow
    Mar 14, 2008
    13,473
    3,361
    The main concern is not to exceed the surge current rating of the device from the capacitive discharge.
  12. shortbus
    Sep 30, 2009
    4,088
    1,667
    The frequency would be varied, ~600Hz to ~6kHz.
  13. shortbus
    Sep 30, 2009
    4,088
    1,667
    The amperage charging the caps would be ~15A @ 95V So I was going to use a 40A @200V SSR.
  14. shortbus
    Sep 30, 2009
    4,088
    1,667
    After spending time reading about DC-DC SSR's, it seems the one that fits my requirements is only good to 950Hz when used with PWM. thanks for all the responses.
